Can anyone help with advice on removing a Vp30 pump from its engine block mount? I have a problem with the size torx bolts socket / spanner. Are these a special tool as the heads seem to taper. The torx spanner appears to be the right size but slips. I do not wish to damage the bolt heads.
Thank you
Thank you
