Hi guys,
I have an odd one that i hope you guys can help with. I have not open the boot for maybe about month (not sure if relevant), I have been driving during this time with no issues. I drove to work fine this morning, Upon leaving my work the boot sounded like it was bouncing as if open, it went over a bump and the boot open light flashed on, for a fraction of a second and the boot starting what sounded like plastic grinding-vibrations, i hit the brakes and immediately it stopped. this was repeated over the next bump before i pulled over. When i went to the back without opening it from the key, I opened physically with my hands and up it came (not locked even though it has been driving for at least 300-400miles with no issue). So when i got home I tried opening the boot with the key it opened fine, when i went to close it,it started grinding/vibration while it is doing this you can hear the relay clicking from the dashboard when i hit the fob release but the boot wont release until it stops vibrating,
Any idea what causing this?
I assume it is a mechanical problem as the relay is clicking when i press the button, so what should i be looking at or for to possibly replace?
Out of curiosity what would cause it to be electronically shut but physically open. I have seen on my old rover it can be physically shut but not electronically as i believe there is like a 10mm gap between the physically lock and where it meets the magnets to energize the lock.
Many Thanks Alex
Many Thanks Alex
