Afternoon all...
Right i have been thinking long and hard about what to do RE hybrid turbo, pressure relief, piping and all that and i just wondered if any-one had any info:
I dont really want to 'ruin' a wingy unit if it all goes a bit pete tong so under those circumstances i am thining it might be simpler to just go custom downpipe with a proper turbo to fit the bill....
I have been thinking about this a fair amount and i am am just not sure how to go about stopping the wastegate opening up and bypassing the turbo far to easily....
If we dont get the exhaust flow going via the turbo, then we dont hit the desired boost pressure or lag is increased as the external wastegate pops open when there is the EMP spike then closes again when it drops off again only to start to open when we hit the higher exahsut flows again.
So i am asuming that i am going to have purchase an electronic boost controller in order to add an element of time delay into the mix
I am happy to get some readings for people if that is what is desired still, but i think i am going to see if there is an alternate turbo that can be used that will be fairly easy to fit, or possibly get something made up if i can find a cost effective solution.... (got a lead for some-one to talk to outside of the normal turbo companies)
I know that Matt was going through a turbo company for the 'stage 3' that wasn't the turbo centre, but i will probably ask them for some advice all the same - seeing as they did the hybrids to start with, they should know the compressor map\flow characteristics of what they built...
So i guess to sumamries i am trying to work out all the options available before i commit to the poressure relief path when it might actually be easier and more cost effective to just ditch the hybrid and start over.... (if i am able to use a 2nd hand turbo it might even break even with selling the stage2!)
- A Turbo that has the same or similar spool characteristics as a stage 2 unit - EG has hit max boost by about 2500rpm, but with a larger exhuast housing
