1 - 2 of 2 Posts
Hello everybody.
New member here with a basic question regarding fitting of wind deflectors on an MG TF.
I've just bought a good quality perspex deflector from a used part MG dealer who said it was a Rimmer Bros.
It's in really good nick, but I'm a bit confused about fitting.
The base of deflector is moulded plastic which rests on top of Tbar (no drilling job)
If I try to fasten it down tightly with studs in place, it's just too loose.
Fasten it down using the screws only, then it's a secure, tight fit.
Is this okay?
Thank for reading,
Kev
I assume its a tight fit with the studs not in place? Unless you want to fit a tonneau at any time it should be no problem, other option may be to get slightly longer screws?
1 - 2 of 2 Posts
