1 - 2 of 2 Posts
mgf
Hi I'm undertaking the conversion of my subframes to TF.
And I'm pretty much there with the rear one. Although I seem to be missing a metal shim that goes between the compliance bush and the lower rear arm.
I've tried to fined this on line with no luck.
Would anyone know where I can buy? without purchasing a whole bunch of used bushes and arms again.
Or I will have to fabricate some put of 5mm steel plate.
Cheers.
Cheers.
Hi after I fitted poly bushes I could not get the shim in so left it out, passed MOT no play. So its up to you, but they are hard to find. Regards.
1 - 2 of 2 Posts
