41 - 45 of 45 Posts
Rover Lifestyle
Rover 200 Rover 600
Discussion Starter #43
NOTE that in some cases in MG F cars, when Heated Rear Window relay (HRW) is not mounted (for example there was no hard top when leaving factory), relay base does not need to be present below two other relays on the right hand side of the fuse box (Window Lift Relay and Engine Bay Fan Relay) as per picture below:
135838
Relay base can be tucked away behind fuse box and need to be searched for (on next picture you can see HRW relay base with yellow HRW relay mounted behind fuse box):
135839
This one?
I was not thinking straight, (another story) and put the battery in the wrong way round, now the battery light is on permanently, would it be this fuse that's blown, everything else apart from the radio works although not checked the alternator output yet
41 - 45 of 45 Posts
