rover_75_tourer
When taking the front suspension apart is there a need to remove the pinch bolt completely or can I just loosen it off a few turns?
rover_600
Hi if it is the pinch bolt on the bracket at the bottom of the strut, it just needs backed off a few turns.
Alan
It is a dri-lock bolt so you need to take it out so that you can fit a new one, or add a bit of Loctite if you are using the old one.
