1 - 5 of 5 Posts
Hi can anyone help with this? Passenger door glass was going too high, removed door card etc only to find the top hat glass stop in the bottom of the door replaced the same and now glass doesn't seem to go high enough. Is there any other adjustments that can be made to remedy this. Any help or advice most welcome. Regards to all.
The stop that you replaced is adjustable. Loosen it, take the window up on the switch to the desired height, then tighten it again.
Hi many thanks for your reply. I'm not sure that it is adjustable as it bolts through the glass via a non elongated hole, can you elaborate more on how this can be done. Regards.
  • Like
Reactions: Chris T
1 - 5 of 5 Posts
