Hi,
does anybody know where is it possible to get the gasket/seal/grommet bettwen the brake master cylinder and brake fluid reservior? Would EJP1502 from rimmer bros be the correct one?
I need it for MG ZR 2.0TZD 83kW 2003 with ABS.
Does this kit have it used those guys for many brake repair kits
rover_sd1
I used a ford seal in my tdi that I purchased from an aftermarket motor spares using the original as sample. Replaced five years ago never had a problem. Rimmers are very good at matching parts using part number and are quite forthcoming if you ask advice.
