1 - 9 of 9 Posts
Hi all, is it possible to remove just the back box? Every article and thread I have read drop the whole exhaust out cat and all.
cheers,
karl
The problem with repalcing just part of the exhaust will be the nuts and blots as they will be non-existent or at best- snap and need drilling out. The back-box can of course be replaced - as many put loud ones on - I fitted a stainless steel TTMk1 to my sons one about 10 years ago. Ive done my exhaust from flexi , re-used CAT and back-box. It took a day but that was mainly re-drilling the CAT on the bench.
cheers,
karl
Yes - I do it every 3 years to satisfy the local vehicle inspector (I do it twice as I then revert back to the box I want on). You may have to take the bumper off depending on the size of the exhaust pipes. I do replace the bolts between the exhaust and the cat to ensure they do not rust up.
Discussion Starter #4
Right another silly question then, as I can’t quite see under the car. Is it a set of nuts and bolts that attach to the cat, so if they snap I can just replace them, or are there studs or threads which would need to be drilled out.
cheers,
Karl
cheers,
Karl
I had forgotten the cat comes with captive bolts. I had mine drilled out so that I could take off the backbox every three years.- the bolts were replaced with normal bolts and nuts.
Discussion Starter #6
I think I may do the same, thanks guys, always like to know what I’m getting into before I start.
karl
karl
Yes, thats why I said mine took me nearly a whole day to do. Good when you have time on your hands (semi-retired). i replaced all nuts/blots and washers 5 years ago now and it looks like 15 underneath! It started with the flexi being blown when i first bought the car home- once you start, you might as well replace all.
1995 MGF Mpi
I've replaced the nuts and bolts with stainless steel, just in case I have to take it apart again some day.
I don't know if anyone has realized this but the captive studs in the cat can actually be pressed out in a vise. No need to drill them.
1 - 9 of 9 Posts
