Hi everyone I recently bought a rover 25 as my first car and need some help on getting some things fixed any advice would be greatly appreciated
Dash Clock - seems to be damaged only shows the hour and not minutes past. Is this an easy fix or is a new one in order
Sunroof seals - The seals are in bad condition and it took a lot of messing about to get the sunroof to sit flush with the roof are there any cheap fixes for this as I live in Scotland and have no intention of using it lol
Coil overs - I was told to look for prosport coil overs but I’m struggling to find any if I’m being honest
Stereo and door speakers - any decent Quality brand suggestions would help
Many thanks in advance for any advice
The sunroof probably needs taking apart. Remove the glass via 4 screws and then you can remove the seal from around it. You will probably find the metal frame is rusted to hell. If you are lucky, clean it up and treat/paint, then refit the seal. You can also buy new seals. I did that with mine some years ago and it kept the rain out!
  • Like
Reactions: gnu
